Welke olie?
What oil...
Dit schreef ik al 2 jaar geleden op een Engels Honda forum:
IvoG wrote:What oil ... for my ____ ? This is a very often repeated question on this forum. Well, I found some interesting information you may find usefull, see the following links:
How To Pick The Right Motor Oil For Your Car - http://popularmechanics.com/automotive/ ... rint.phtml
The Engine Oil Bible -
http://www.chris-longhurst.com/carbible ... bible.html
And for the more technically adept (you'll know if you are :wink: ):
Lubrication :wink: Theoryops: and Practice 8-) - http://www.lubrizol.com/LubeTheory/default.htm
After reading these guides you'll know why the question "What is the best oil for my engine?" is besides the point :idea:
Every engine has had a different owner, service pattern, usage pattern, fuel choice, mechanic servicing it, factory worker putting it together, heat-up / cool down cycles, etc.
That's why naming one oil to use is not a good idea. Better is to arm yourself with the knowledge that will help you determine which oil will suit YOUR car's engine best. Of course you can ask for other opinions, but at the end of the day, that's all they are, just opinions. The effects your choice has on your engine, those are hard facts for your engine.
